2003 praire backfiring all of a sudden
Old Oct 15, 2008 | 02:19 PM
03Praire's Avatar
Default 2003 praire backfiring all of a sudden
hey everyone im new i just wanna say hello.
I have a little problem. I have a 2003 praire. The other night i went out riding and it was running fine for the hour or so i was riding by myself. I went to go meet one of my friends on his quad. I was on my way put of the woods to his house and i made the turn and got back on the gas and it backfired. I though it was normal and continued and it was constantly backfired. I couldn't go anywhere near half throttle. Barely even a quarter. So i honestly had to idle home. So im lost at what it could be.
Some things i eliminated was the sparkplug. replaced it
I also put a bottle of gumout carb/fuel treatment in.
I came here to get some expert advise.
If anyone has an idea or suggestions, id surely appreciate it
Steve
Old Oct 15, 2008 | 03:34 PM
Hayashi's Avatar
Steve,
You have 360 or 650?
Is anything flashing on the dash meter?
If the BELT light is flashing, open up the CVT cover and check the toggle switch position and see whether it is at ON or OFF position.
Old Oct 15, 2008 | 07:29 PM
03Praire's Avatar
sorry i forgot that, yes its a 360.
Yes the best light is flashing,and ever since my friend left them here. it has been flashing for a while he said.
how would i go about checking the switch?
I have mostly dirtbike background, not as much quad
Old Oct 15, 2008 | 08:50 PM
03Praire's Avatar
well i have everything almost done to get the carb, the only thing is how would i go about unlinking the choke cable and the throttle cable? Is it just backing off the nut and should it twist out? thanks
Old Oct 16, 2008 | 01:03 PM
03Praire's Avatar
well i got the choke cable disconnected, and what do i do after backing off the nut for the throttle cable?
Old Oct 16, 2008 | 03:21 PM
03Praire's Avatar
well i have the throttle cable off, i have the carb totally off. how should go about cleaning it
Old Oct 16, 2008 | 05:24 PM
Hayashi's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 03Praire
well i have the throttle cable off, i have the carb totally off. how should go about cleaning it</end quote></div>
Why are you doing all those when the belt light is flashing?
There are tons of threads about flashing belt light in this fourm - do some search.
In short, the flashing belt light means that CVT belt detection system detected a fault in the CVT area (worn out sheaves, loose/worn out/broken belt whatever that can cause the belt switch to trigger). Once that's triggered, the ecu goes into backfiring or limp home mode. Turning off the light is one thing, but you really need to find out why the belt light started flashing first place.
Old Oct 16, 2008 | 05:40 PM
03Praire's Avatar
i have no idea.. but what should I do to check?\
Old Oct 16, 2008 | 06:16 PM
03Praire's Avatar
well i took off the cover to look in and the belt is in good condition by the looks, the is a little play in it, i can take pictures if you want a look for yourself. let me know
Old Oct 16, 2008 | 11:13 PM
Hayashi's Avatar
Just from looking at photos I would not be able to tell whether the belt slack/deflection is in spec or not. There are two ways to measure:
&gt; Applying force (14 lbs) and measuring the deflection (perpendicular to the belt).
&gt; Using the kawi's belt gauge which measures the belt width.
All described in the service manual which obviously you don't have as I assume. You really need one if you would work on the quad and get the job done RIGHT.
The belt should have some play (22 to 29 mm), can't be too tight or can't be too loose.
Is the toggle switch inside/top of the CVT cover at ON or OFF position?
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Hw00d
Sep 10, 2015 08:53 AM
