Baja 90 ATV will not start
Old Nov 5, 2008 | 04:26 PM
swat99's Avatar
Default Baja 90 ATV will not start
2 year old Baja 90 will not start. It turns over, has compression, has spark, and has fuel in the carb. Spark plug is bone dry and I don't think fuel is getting to engine. When I spray a little fuel in the plug hole it ignites. ANY SUGGESTIONS???
Old Nov 5, 2008 | 09:19 PM
ghcoe's Avatar
If it has sat for a long time possible that the fuel has gelled in the carb or circuit lines. One thing you might try if it has a float bowl drain is open it to see if fuel runs out. It not possible that the floats are stuck and holding the needle seat shut. Try tapping the carb very lightly with a hammer. A brass hammer would be the best but if careful you can use a regular one.
Old Nov 5, 2008 | 11:30 PM
swat99's Avatar
I had taken the carb completely apart and cleaned it, lines included. There's plenty of fuel in the bowl, just doesn't seem to get to the ignition phase.
Old Dec 2, 2008 | 01:04 AM
Canadian144's Avatar
Sorry to bring up a kinda old thread, but Jim when I had a problem with my Baja I contacted them through the phone # on their website... eventually I got the right stuff and it worked out OK. If you haven't already contacted them, I would give it a shot.
Old Dec 2, 2008 | 11:05 AM
LT80's Avatar
LT80 Expert
I'd try hand choking it. Put 2 fingers in front of the carb and try to start.
Old Aug 14, 2012 | 07:56 AM
Dlloyd560's Avatar
Does anyone know about this problem. I have a 2005 baja 90 I bought 3 years ago. It ran great. Its getting harder and harder to start it takes me about an hour a can of starting fluid and jumper cables. But once it's started and warm it runs fine and starts right back up. If it sits not running for more the 1/2 hour its back to not starting. I have spark I have fuel in the carb after cranking for a while the spark plug is dry. I have taken the carb apart and cleaned it it's spotless. Does any one have any ideas I don't want to buy the wrong parts.
Old Aug 14, 2012 | 11:09 PM
LynnEdwards's Avatar
Electrical Expert
Is this a four stroke engine? If so, this is *classic* symptoms of tight valves. When was the last time you adjusted the valves? This is routine maintainence and needs to be done periodically.
Valves tighten with wear, and tighten some more when cold. The first symptom of tight valves is hard starting cold - getting progressively worse over time until eventually it won't start at all. But if you do get it started and warmed up it runs perfect and starts perfect - until it cools back down.
Old Aug 15, 2012 | 05:58 PM
Dlloyd560's Avatar
Thanks for the replay I ajusted the valves and tha atv started right up cold with no choke the intake valve was tight. Thanks again it worked great!
Old Aug 15, 2012 | 11:12 PM
Electrical Expert
I'm glad you got it working .
Bleach
1) Engine problems..
16
May 16, 2021 08:23 AM
Jun 15, 2015 11:22 PM
JackTheKing
Jun 14, 2015 03:04 PM
Jun 8, 2015 06:45 PM
1000gade
May 27, 2015 12:37 PM
