warrior problem
Old Nov 8, 2008 | 05:40 PM
taylorteamracing's Avatar
Default warrior problem
well i replaced the cdi i replaced the stator i replaced the coil i replaced the pickup coil now when i use the push button start switch it only sparks when you take your finger off the button i tried jumping the starter solonoid i eveb tried jacking the rear wheels i put it in high gear and spun the tires again no spark i check everthing over and still didnt get it going if anyone has any ideas please let me know
Old Nov 8, 2008 | 11:50 PM
i went back and checked with my meter and found the source coil at 230 ohms the minumum spec is 270 the other one i have is 285 i found the pick up coil at 180 the ignition key switch checks out with the continuity test the electronics are off of a 96 and i have them on a 95 and they all came off of a running machine wire color code was the same just had to change the conectors
Old Jun 30, 2009 | 08:57 PM
Rickeyparker's Avatar
Im working on some solutions for this problem Ill post as soon as i find something, right now Im checking all these cheesy wires routed throught the beast of a mess. RP
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
