27-11-14 on the 850 XP
Old Nov 26, 2008 | 02:37 PM
600Grizzly's Avatar
Default 27-11-14 on the 850 XP
Well here is what I found. They almost fit, when the machine is sitting with it's own weight there is 1/2 in clearance as you pull down on the bush guard the space increases but if you lift up on the bush guard the space decreases to the point it would scuff the tires. The issue is if the back end comes off the ground it might rub the tires enough to hook one of the lugs. It may never happen but.
So I've ordered 1 1/4 spacers for the rear which will make the bike sit wider and it will also put the disc brake into the larger ID of the rim giving me an inch of clearance between the top of the caliper and the ID of the rear wheel. So it will be less than half the price of rims and should be a good fix for the wider tires.
Take good care
Dave
Old Nov 26, 2008 | 10:03 PM
rancher55's Avatar
Alright Dave!
That sounds good but the only question I have is that in some states there is a max. width for ATV's. What does that put yours at? 50"? It seems like your bike would be a little more stable on sidehills though. What do you think?
Take care and keep us posted!
rancher
Old Nov 26, 2008 | 10:46 PM
600Grizzly's Avatar
It should end up at 50.6 inches. I know it won't fit in my 4X8 trailer anymore but I've got an 8X12 to take care of that little problem. I think it should dig and go really well. The tires stand quite a bit taller than the stock ones. I'll have to check the pressure they left them at before I go riding. I want to put the spcers in before I take it out just in case the tires do rub or catch.
Take care,
Dave
Old Nov 27, 2008 | 12:14 PM
Rutcutter's Avatar
Those are the exact tires im looking into myself and I also want to keep my browning rims,how much do the tires stick out past the fenders? Im looking to keep them stuffed under for mud protection. I was thinking maybe we could bend the sway bar end in alittle but its prolly to stout.
If you have any pics post them up for us,also what kind of coin did they run ya?
Old Nov 27, 2008 | 08:06 PM
triplggg's Avatar
Pictures please.
Old Nov 27, 2008 | 10:38 PM
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Rutcutter
If you have any pics post them up for us,also what kind of coin did they run ya?</end quote></div>
Believe it or not the sway bar is hollow and should bend fairly easy. Just be careful not to crease it. With the right tubing/pipe bender it should be easy to bend enough for the needed clearance. You could probably do it in a vise but you need to be careful. Either way heat would help.
Old Nov 29, 2008 | 08:22 PM
Rutcutter's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 600Grizzly
Take good care
Dave</end quote></div>
Will you post up some pics of how the tires look on the stock wheels? Snap one for me showing the fender coverage if ya will.
Old Nov 30, 2008 | 12:43 PM
lobodog3's Avatar
Hi.
I have no problems with mine,
It looked too close at first but riding all day yesterday i had no issues with my 27 inch swamplites 9 front 11 rear.
And my bike still fits in my trailer.
So dont waste your money on spacers and crap.
spend it on gas and cleaning supply's
Old Nov 30, 2008 | 01:48 PM
HIGHOCTANE's Avatar
I think I'd be more inclined to try bending the sway bar a little,just be careful not to kink it. Shouldn't take much. Or even try it with it removed before adding spacers. One person reported removing it and said it actually handled better on the trail in his opinion. But I would be cautious with it removed if you do higher speed cornering,it might loose some stability. But since there isn't one up front the change might not be even noticable. For it to be fully effective it needs a sway bar up front as well. One way to find out! lol
nontypical234
Jun 27, 2010 08:58 PM
lovmudd
Jan 29, 2010 06:42 AM
lovmudd
Jan 21, 2010 12:52 PM
hamweena
Jan 12, 2010 09:36 AM
yellow bird
Dec 22, 2008 09:57 AM
