Engine won't turn
Old Jan 10, 2009 | 12:17 PM
freeURman's Avatar
Default Engine won't turn
450 foreman won't turn over. Thought originally it had siezed up. It will turn fine without the spark plug. So i took a look at the valves. No damage there. After adjusting the valves it started to turn. Turned over but wouldn't run without the choke pulled fully. Smoked like crazy. After about a minute of trying to start it siezed back up. Is the timing chain stretched?
Old Jan 10, 2009 | 07:39 PM
cherokee99's Avatar
if its been sitting you may have no lubrication, and if you have to use full choke its likely the carb needs cleaned
Old Jan 10, 2009 | 11:46 PM
JeffinTD's Avatar
Could the cylinder be full of water, or say gas from an overflowing carb?
Liquid won't compress, so if there is some in the cylinder, that would cause the motor to lock, but turn freely if the spark plug was removed...
Old Jan 11, 2009 | 05:49 PM
freeURman's Avatar
I messed with the valves some more and got it running. Smokes really bad and sprays oil out the exhaust. I guess those valves weren't ok after all. I'm gonna rebuild the top end
Old Jan 12, 2009 | 04:38 AM
BlueRubie's Avatar
O boy. . . Sounds like sombody cranked the valves down to try for a better seal. . . rebuilding the head won't do you much good if shes throwing oil out the exhaust. . .
Time for a Jug n Piston assembly. . .
1. Piston.
2. Rings.
3. cylinder.
4. Feul Filter.
5.Carb kit.
6. Spark plug.
replace these i bet it run perfectly. . .
Mikey !
Old Jan 18, 2009 | 05:03 PM
freeURman's Avatar
There's discoloration up the exhaust valve. Is it possible the oil out of the exhaust is getting in past the stem seal. There's still good compression and no marks on the cylinder wall
Old Jan 18, 2009 | 07:11 PM
JeffinTD's Avatar
Stem seals can leak oil.
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
