Gas pours out of carb as soon as gas is turned on... Help!?
Old Jan 11, 2009 | 12:34 PM
Evader53's Avatar
Default Gas pours out of carb as soon as gas is turned on... Help!?
I have a 2000 warrior and haven't run it in approx. 5 weeks. Today I went to start it up and as soon as I turn the gas on, gas goes pouring out of the overflow tubes on the carb. I tried heating up the carbs with a blowdryer, but still had no luck.
I am able to start the quad when the gas is off (apparently just enough gas gets through the line to allow it to idle), but as soon as I turn the gas on, the engine sputters then dies, and gas goes pouring out of the carb.
Does anyone know what the problem may be and how to fix it!?
Thanks
Old Jan 11, 2009 | 05:13 PM
scrambler400enoge's Avatar
Shapeshifter Rider
A post in the yamaha forum may help.
Old Jan 12, 2009 | 01:11 AM
Sidewinder500's Avatar
sounds like your float is stuck
Old Jan 12, 2009 | 02:10 AM
tallman01's Avatar
it does sound like your froat is stuck, tap on the bowl with handle of a screw driver and see if it quits dumping fuel
Old Jan 12, 2009 | 05:55 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Either your float needs adjusting, or the needle valve has a bit of grit underneath it holding it open. What I do, is go out and land a few huge jumps, and usually that will get a stuck needle freed up....
Old Jan 12, 2009 | 09:11 AM
Stoopidbot's Avatar
I would think the float is most likely to be the problem.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
Blodg500RX
Jan 8, 2001 05:15 PM
