front tire height
i am ordering new front tires for my banshee. i plan on ordering holeshots. should i go with 21x7x10's or should i go with a taller size? on the rear i run 20inch holeshots, and i am also getting a set of realtors 22inch on wheels for the hillclimbs.
also what front tire do you like the best? are razrs better than holeshots? thanks
Personally, i would get the Holeshot 21x7-10's. They are a good all around tire that will work well with the 20" rears. If you are only going to hillclimb with the realtors the size of the fronts doesn't really matter, unless you need more ground clearance. A taller tire won't turn as fast as a shorter tire. So if you ride trails, the 21's are the way to go.
JackTheKing
Jul 14, 2015 09:09 PM
