front tire height
Old Feb 8, 2001 | 07:13 PM
H300F's Avatar
i am ordering new front tires for my banshee. i plan on ordering holeshots. should i go with 21x7x10's or should i go with a taller size? on the rear i run 20inch holeshots, and i am also getting a set of realtors 22inch on wheels for the hillclimbs.
also what front tire do you like the best? are razrs better than holeshots? thanks
Old Feb 8, 2001 | 07:21 PM
54warrior's Avatar
Personally, i would get the Holeshot 21x7-10's. They are a good all around tire that will work well with the 20" rears. If you are only going to hillclimb with the realtors the size of the fronts doesn't really matter, unless you need more ground clearance. A taller tire won't turn as fast as a shorter tire. So if you ride trails, the 21's are the way to go.
Old Feb 8, 2001 | 07:26 PM
H300F's Avatar
thanks for the reply... yeah i will mostly be using the 20inch holeshots, and sometimes the realtors just for hillclimbs.
now what is better, holeshots, razrs, or ? for the front
Reactant
Mar 30, 2022 02:08 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
