04/05 honda rancher 350 full time 4x4
Old Feb 4, 2009 | 08:27 PM
Hawkman300's Avatar
Default 04/05 honda rancher 350 full time 4x4
my dads gettin one for $2500 from a friend of his. just wondering if theres anything i should know about it? how does it do in mud with stock tires and all? wats top speed?
Old Feb 7, 2009 | 04:04 PM
Hawkman300's Avatar
ok, just got it, ran about a tank thru it, runs great, lots of fun. been sittin for awhile, so im gonna do full maintenance on it. im gonna change engine oil, and both gearcase oils. im also getting a UNI air filter for it. is there anything else i should do?
Old Feb 8, 2009 | 12:02 PM
fourweeln's Avatar
If you want to be able to take it in, and out of fourwheel drive Warn makes a 4-2-4 selector kit. It replaces the frount drive shaft wit one that has a little doghouse on it, and a cable so you can engage and disengage the frount dif. It makes it better when trail riding so you can power the rearend around a turn.
Old Feb 8, 2009 | 06:24 PM
Y2daT's Avatar
gear case ?you mean differentials.....
i have the 424 kit on a 300 fourtraxx a nice addition.....
it will preform well with stock tires and handel good ....larger grippy tires will do better in the mud but sacrafice handeling(most 300 and 350 owners say any thing over 26" are to big for this machine)
you may want to get a jet kit to go with your unifilter so it dosnt run to lean??
and check the vent lines coming from the engine case and differentials..to make sure there not dry rotted...
Old Feb 9, 2009 | 06:52 PM
Hawkman300's Avatar
how much is the warn 424 kit? and would a jet kit really be necessary for a uni filter?
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Rancheres4X4
May 5, 2000 02:09 AM
undecided
Sep 7, 1999 05:42 PM
