adjusting rear shock on 2001 Polaris Scrambler 500 2x4
Old Feb 26, 2009 | 09:21 PM
tyanna's Avatar
Default adjusting rear shock on 2001 Polaris Scrambler 500 2x4
Can the rear shcok be adjusted? If so, how? Even with a 100 lb person riding the rear end squats pretty low. If it can be adjusted then how do we know how much to adjust it? Any help appreciated.
Old Feb 26, 2009 | 09:28 PM
tyanna's Avatar
Thought I should add, we are wondering if it can be adjusted or needs rebuilt. It sounds like air coming out when the rear end goes down...
Old Feb 26, 2009 | 09:47 PM
cabledawg71874's Avatar
Lift the rear end up to take the pressure off the tires and grab spring and rotate. That is only if it has a fox shock. You might have to replace it. I had to do that from a 8' jump I did. Popped the shock. Hard landing.
Old Feb 26, 2009 | 10:05 PM
tyanna's Avatar
Yup, it's a fox shock. Thanks.
Old Feb 26, 2009 | 10:09 PM
if it still sags after you tighten it. Most likely you will need to replace it. They run around the 300 buck mark. But, you will have to swap out springs yourself or get the dealer to do it.
Old Feb 27, 2009 | 06:01 AM
ftwflh's Avatar
THe FOX setup will sag.But it is designed like that.Start with the setting in the center then work tighter or looser until when you hit a big bump it doesnt bottom out.
Old Feb 27, 2009 | 09:23 AM
tyanna's Avatar
If it does need to be replaced can it just be rebuilt?
Old Feb 28, 2009 | 02:27 PM
ftwflh's Avatar
FOX shocks are rebuildable
polaris scrambler00
Jun 20, 2015 08:49 AM
Big600twin
14
Jun 16, 2015 09:30 AM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
