07 ES Rancher chugs during take off
Old Mar 18, 2009 | 02:32 PM
Crutch's Avatar
Default 07 ES Rancher chugs during take off
When I try to take off in 2 or 3th gear it chugs like it doesn't have gas.
If I shift to neutral and rev the engine it sounds fine. Then I shift back to 2nd and no problem taking off or riding. About 100 hours on it. Any clue?
Old Mar 19, 2009 | 06:58 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
What happens if you take off in 1st???
2nd gear takeoffs are ok on level ground, but 3rd gear, no way. If you have been doing 3rd all along, I am not one bit surprised that your clutch is now toast.
Have you done a clutch adjustment lately????
Could be that your ES isn't putting it into gear properly?
Old Mar 19, 2009 | 01:09 PM
Crutch's Avatar
No clutch adjustment done yet. I didn't see it listed on the scheduled maintenance chart.
I assume it's in my manual.
I'll look.
Old Mar 19, 2009 | 02:47 PM
colt2245p's Avatar
WHY dont you take off in first gear ????? the only time i could recomend taking of in a higher gear would be going down hill....
Old Mar 20, 2009 | 07:51 AM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: Crutch
I'll look.</end quote></div>
It's there in the maintenance schedule, under "Clutch System"......
Old Mar 25, 2009 | 03:25 PM
Crutch's Avatar
I had both my 07 Ranchers out this weekend and the "chugging" happens on one.
I don't believe it has anything to do with clutch or starting in second gear.
Always have started in second unless I was pointing up hill.
If I start downhill, it chugs. Shift to neutral and back to second, no problem. Takes off fine.
Maybe an issue with position sensor? Dashboard nevers shows any "-" , always shows gear.
Old Mar 25, 2009 | 09:54 PM
Red Rider
Maybe just another case of a faulty ES system????
Old Oct 15, 2022 | 08:15 AM
Moham -Ed's Avatar
Default I have the Same problem with my manual Shift
[QUOTE=Crutch;2762137]When I try to take off in 2 or 3th gear it chugs like it doesn't have gas.
If I shift to neutral and rev the engine it sounds fine. Then I shift back to 2nd and no problem taking off or riding. About 100 hours on it. Any clue?[/QUOTEIf the engine is completely cold (left over night) it is fine but if I run it a little then shut it off and restart it it chugs
Old Oct 16, 2022 | 02:17 AM
Do not set off in any gears but 1st or reverse. Honestly, why do you think you have to put it in first before you change up into second?
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
