98 sportsman 500
Old Apr 23, 2009 | 09:31 AM
atv gooroo's Avatar
Default 98 sportsman 500
Hi all. I am currently helping a freind revive this bike. The bike runs great until you drive it down a ditch. If I ride up the truck ramps backwards and sit for a second it will shut off. I can sit up hill just fine. Any thoughts? The clutches are out of alignment too. I can't idle it but so high for it will engage. I have some secondary shims but am having trouble romoveing the secondary. If I remove this secondary will this cause me to have to do the preload thing? I have a 05 so things are a little different. It has a busted boot too but I am concerned on the procedure since this bike has the locking hubs. Any advice would be great.
Old Apr 23, 2009 | 10:15 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you guys do carb work? maybe the float is out of adjustment. sounds like it ran out of gas?? as far as the secondary goes, as long as you dont take off the c clip that holds the helix on you dont have to preload the spring.
Old Apr 23, 2009 | 11:18 AM
atv gooroo's Avatar
Yes we did do carb work. Every jet in there was stopped up completley, but it is 100% clean now. We could not even start it and after I got through with the carb when we pushed the button for the first time it started and ran good. How do you adjust the float. I am new to the whole carb thing to atvs but not so much push mowers. I saw the float and the needle. I took the float and needle out and cleaned and reinstalled. I really didn't see an adjustmant.
Old Apr 23, 2009 | 11:19 AM
eggenz7's Avatar
the secondary clutch should just slide right off the input shaft. it has straight splines like an axle does. the primary is the only one that needs a puller
Old Apr 23, 2009 | 11:34 AM
atv gooroo's Avatar
The secondary on this machine as seized and it does have threads on the inside walls of the secondary for a puller. I bought a 1 inch fine thread bolt and am going to find something to put in the hole and then thread in the bolt and see if it will push it off. I used the 3/4 fine thread bolt and an extension to get the primary off one of my machines. I hope it works.
Old Apr 23, 2009 | 02:31 PM
atv gooroo's Avatar
I think Stendori is right. I quess I need to bend the float where it attatches to the needle just a little to get more gas into the bowl. I have searched and read some on this but alot of peoples problems are when going up hill and not down. But I feel like I am running out of gas like was said because I can incline the rear and it will idle a little and then I will shake it from side to side and it cuts off.
Old Apr 23, 2009 | 05:14 PM
eggenz7's Avatar
maybe the filter in the tank is bad/dirty and needs to be cleaned. you got a full tank of gas for this test right?
when you set the float it should be parallel with the carb body (carb upside down sitting on the throttle neck)
Old Apr 23, 2009 | 05:49 PM
atv gooroo's Avatar
I can get to stop cutting off on the ditch bank when I remove the fuel hose off of the right side of the carb.(side as if sitting on) This hose runs up to the fuel pump I guess. I think that it puts a sucktion on it because if I cover the tube with my finger it cuts right off. I can't get it to shut off on the hill with this removed. ????
Old Apr 24, 2009 | 07:22 AM
Kerbbirds's Avatar
That line provides the vacume to the fuel pump, shouldnt have anything to do with your problem, the float should be level with the bottom of carb when upside down on a flat surface, the secondary should come off, spray penetrating oil in the hole, get a large punch and hit the end of the shaft a couple times, pry on back of clutch a little then have someone hit the shaft, they can be sticky but Ive always gotten them off.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
