EPI clutch springs
Old Apr 28, 2009 | 11:15 AM
midnightxplorer's Avatar
Default EPI clutch springs
What color is everyone using in the rear clutch? is there a reduction in top speed?
Is there a chart to compare it to polaris stock ones?
thanks
01 500 HO.
Old Apr 28, 2009 | 03:20 PM
I found a spring chart no sure how to read it though....
Spring Chart
Old Apr 28, 2009 | 04:45 PM
ftwflh's Avatar
That chart is for sled springs.EpI has dif ratings for ATV springs.
On just changing you secondary (rear clutch) spring (or just the setting) you can gain top end but loose lowend and back shift.Or gain backshift and low end but loose topend speed.You get a complete understanding of the CVT system and you can get what you want without loosing much of anything.But it gets expensive buying springs and weights until you get it right.
Old Apr 28, 2009 | 07:20 PM
I just want slightly better belt grip in high gear...it should wheelie in high range...i think with the mods i have done...
Old Apr 28, 2009 | 08:14 PM
ftwflh's Avatar
you ride a Sportsman or Scrambler
Old Apr 29, 2009 | 04:50 AM
I ride a sportsman. I here of people doing it but they lose there top speed...i did wieghts in my front clutch, and i left the stock spring in it for the low engagement. It works good now just looking for a little more.
Old Apr 29, 2009 | 05:54 AM
ftwflh's Avatar
With heavier weights and stock spring you may not be getting full shiftout.
If you plan on messing with your clutch you may wantt o invest in Aaens Clutch Tuning Handbook.It will enlighten you to what does what and how to get what you want out of your clutch
Old Apr 29, 2009 | 07:48 AM
thanks
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
