94 warrior i need more power!!!
Old Jul 26, 2009 | 03:08 PM
bigbucks4me's Avatar
Default 94 warrior i need more power!!!
i have a 94 warrior 350 and i would like more low end power i like doing wheelies and such things i alreadt put a 11 tooth front sproket on it is there anything i can do to get more low end with out spending alot of money other then the srockets its all stock including the stock gutted pipe
Old Jul 26, 2009 | 06:22 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
go up to a 12 tooth front sprocket.. why do you need more power? with a stock quad with stock gearing i had no problem doing wheelies on my warrior.
Old Jul 27, 2009 | 07:53 AM
Kevin R.'s Avatar
There's realy no cheap thing to do. Cheapest would be carb jetting and air filter, but still looking at about $100. Then it's cams and topends. $400-800?
Old Jul 27, 2009 | 09:12 AM
wheily's Avatar
might want to get a pipe as i gutted mine and lost a hole crap load of torque
Old Jul 27, 2009 | 12:28 PM
Kodiak450_06's Avatar
Thats most likely your problem, you gutted the pipe. I know when I taje out my spark arrestor assembly and use a power tip in replace of it, i lost some low end and really noticed it while going through mud holes. You might want to put guts back in pipe and see if you notice any gains in low end.
Old Jul 27, 2009 | 06:47 PM
Speedy2222's Avatar
It's hard to compare stock to just pipped anymore for me.. especially after i did my cam and other goodies. It really has torque like you wouldn't believe!!!
Old Jul 28, 2009 | 11:00 AM
91Warrior357's Avatar
you can re gear if you want but its not adding power its just changing your ratio, if you want more power just start out with the basic three mods, pipe, filter, jet kit something like, a White Bro E-Series slip on, Yoshi Rs-3, HMF Sport pipe, K&N clamp on filter kit or Uni Foam, and then just get a Dyno-Jet kit... if you still want more power then get a good cam and piston like a JE or something...if your still not satisfied then get better valves and springs, port it and get a bigger carb like the Edel Quicksilver, with the mods i have on mine its quick for a warrior, very snappy and lots of low end and mid range power, keeps up with 400s and other bikes pretty well.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
