2000 Polaris sportsman 500 RSE Oil in recoil housing
Old Jul 28, 2009 | 07:31 AM
tandtprine's Avatar
Red face 2000 Polaris sportsman 500 RSE Oil in recoil housing
Hi! I looked through the forums and could not find info on this.
I just took my recoil housing off and there was oil in it. I am guessing it is the oil seal behind the magneto. I just want some other thoughts. This is my first quad. I bought it for the learning experience, and boy has it ever been! lol
Do I have to buy the Polaris flywheel puller, or will one of the universal ones work??
Thanks! Tiffany
Old Jul 28, 2009 | 09:09 AM
02magnum500's Avatar
Gets his share of deer.
I had a 2000 magnum 500 with the same issue, there was a seal/o-ring in there that was pinched on mine.
Old Jul 28, 2009 | 09:25 AM
tandtprine's Avatar
Ok.. talked to the guy I bought it from. He said that he put gear oil in it to keep it from rusting, etc. However, i still want to check the seal, etc... Anyone know if i can use a universal puller or a pulley puller to pull the rotor??
Old Jul 28, 2009 | 09:48 AM
wow, I would clean all the oil out of there.....you should be able to tell if it is actually gear oil by it's smell and thickness it has to it probably the color too. Not sure on the puller though.....
Old Jul 28, 2009 | 10:00 AM
TLC's Avatar
TLC
Mine had dirty water get into the recoil housing,when I took in apart it looked oily but its just the water picks up oil from the Bendix and recoil assy.
I re lubed the Bendix drive, and siliconed the pull rope handle it its place ,nothing will get in again that way, The pull rope handle does not sit tight enough on it's own to count on it.
Old Jul 28, 2009 | 07:52 PM
tandtprine's Avatar
Its gear oil... Ick! lol
yellowpolaris
Jun 21, 2015 11:13 AM
DOAinNY
Jun 11, 2015 10:34 PM
wbfjim
Jun 8, 2015 06:20 PM
FourtraxRancher
Nov 25, 2000 03:47 PM
Peeps
Mar 24, 2000 12:27 AM
