250R Clutch Broke, Need Help!
Old Feb 20, 2001 | 05:40 PM
rigoni's Avatar
My 88 250R clutch went out this weekend. I am planning on taking it apart next week. Want to see if anyone knows what the problem is before I open it up. Here is the problem: The clutch went out. The clutch has no resitance on it, pull the cable the rod moves with no force (not the cable). The cluch rod can't be pulled out freely (not a broken cluch rod.) Do any of you have an idea what it could be?
Thanks,
Old Feb 20, 2001 | 07:48 PM
fivel250rman's Avatar
You say the clutch rod cannot be pulled out freely .Are you talking about the clutch lifter;the thing that hooks onto the motor end of the clutch cable?The clutch rod is the thing that the clutch lifter pushes on,that runs through the middle of the hollow shaft the clutch basket is bolted on.Anyway it sounds like one of those two parts are bent or broken.
PS If its not an 89' get the clutch update that gets rid of the ball and has needle bearings on the end.
88' 250R many extras
Old Feb 20, 2001 | 08:15 PM
rigoni's Avatar
I am sorry, your right, I meant the clutch lifter won't pull out, so I know that isn't broken. It has no resitance on it when I turn it. So you think it might be the acutally rod that is broken?
Thanks for your help.
Old Feb 20, 2001 | 09:29 PM
400exalltheway's Avatar
my guess is the pressure plate broke. thats the first thing that comes to mind. let us know what it actually was. oh yeah, did it go out while you were riding? you make have damaged other things so check everything carefully
Old Feb 21, 2001 | 02:00 PM
Either way you'll have to pull your right side case cover to find out for sure,and like 400exalltheway said inspect all surrounding parts thouroghlly.
Old Feb 21, 2001 | 02:01 PM
Old Feb 21, 2001 | 04:38 PM
retro's Avatar
You will not be able to pull the lifter rod out untill the push rod is pulled out through the right side of the engine.
ERIC
Old Feb 22, 2001 | 06:42 PM
True unless it was broken which was what he was checking for.
Old Feb 23, 2001 | 11:31 AM
rigoni's Avatar
Thanks, for your input. I am going to pull it apart next week, and will let you know the outcome.
buddieboy
Dec 9, 2016 05:50 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
jbrewster94
Sep 23, 2015 04:16 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
