250R Clutch Broke, Need Help!
My 88 250R clutch went out this weekend. I am planning on taking it apart next week. Want to see if anyone knows what the problem is before I open it up. Here is the problem: The clutch went out. The clutch has no resitance on it, pull the cable the rod moves with no force (not the cable). The cluch rod can't be pulled out freely (not a broken cluch rod.) Do any of you have an idea what it could be?
Thanks,
Thanks,
You say the clutch rod cannot be pulled out freely .Are you talking about the clutch lifter;the thing that hooks onto the motor end of the clutch cable?The clutch rod is the thing that the clutch lifter pushes on,that runs through the middle of the hollow shaft the clutch basket is bolted on.Anyway it sounds like one of those two parts are bent or broken.
PS If its not an 89' get the clutch update that gets rid of the ball and has needle bearings on the end.
88' 250R many extras
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
