baja 90cc atv sputters and bogs at 3/4 of the throttle
Old Aug 31, 2009 | 05:35 PM
daniel776's Avatar
Thumbs down baja 90cc atv sputters and bogs at 3/4 of the throttle
hi i have a baja 90cc atv which i bought from someone and whenever i try to do full throotle it bogs and spuuters it sounds horrible i changed the gas and the fuel filter and the plug is wet with gas can you please let me knw whats wrong with my atv i wanna get back to riding
Old Aug 31, 2009 | 08:05 PM
alltruckrage's Avatar
all I can say is rebuild the carb ,I have the same quad and have a wiring issue and could really use a wiring scamic to see atleast the cdi box and how it goes plug wise with colors a pic or a manufacture's web site would help alot!!!!!!!!!!!!!
Old Aug 31, 2009 | 08:28 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum daniel776 and alltruckrage !
daniel776, I would start with alltruckrage's suggestion and clean the carb..
I moved this to the Chinese section where its get seen more...
Old Aug 31, 2009 | 08:46 PM
LT80's Avatar
LT80 Expert
To add...we think the main jet is clogged/obstructed.
Old Sep 1, 2009 | 12:24 AM
LynnEdwards's Avatar
Electrical Expert
AllTruckRage,
When you say you have the same quad is it a *Baja* 90cc quad. They have owners manuals online with schematics (wiring diagrams) inside. Check out the following link:
Baja Motorsports | Owner's Manuals | Assembly Instructions
If you need further help just ask.
Old Sep 1, 2009 | 06:11 AM
Originally Posted by LynnEdwards
AllTruckRage,
Thankyou for the information but I need to know where the wire's go in the plastic plug in the cdi box there's two plug's one two prong and one six prong I need the two prong is two wire's but the six prong is five wire's in with an open slot I need to know where the wire's(w/colors) go corisponding to what slot???Thankyou again!!!
Old Sep 1, 2009 | 10:44 AM
Electrical Expert
Are you sure the CDI plugs are 2 pin and 6 pin? I've not seen nor heard of a CDI like that. Acording to the Baja wiring diagram and the Baja web site parts section, the CDI has a 2 pin and a 4 pin connector set. Here is a picture of that CDI:
The classic color scheme for the above pins is:
Ignition Power: Black with Red Stripe
Kill Switch: Black with White Stripe
Ignition Trigger Pulse: Blue with White Stripe
Ignition Coil: Black with Yellow Stripe
Ground: Green
Many, but not all quads follow this color scheme.
If you really do have a 2 pin and 6 pin CDI can you post a picture of it? Also, what are the wire colors for all the wires going to the CDI?
Old Sep 1, 2009 | 07:48 PM
daniel776's Avatar
i cleaned the carb twice and the plug came out black every time i put a new one in should i change the oil
Old Sep 1, 2009 | 08:41 PM
Default No spark???
I have a motoss-90 that somehow has last it's spark I checked and replaced the cdi box but nothing, am I missing somthing all the year's I'v lost spark it's alway's seemed to be the cdi box can someome please point me in the right direction PLEASE !!!!
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
ghost civic
Jul 30, 2015 04:09 PM
