07 Polaris Sportmans 500 HO, won't start!!
Old Nov 2, 2009 | 12:34 PM
08SPORTER's Avatar
Default 07 Polaris Sportmans 500 HO, won't start!!
Alright the girlfriend has a 07 Sportmans 500 that has sat idle for about two months. The first issue was a dead battery. Now I can't get the thing to start. It will sit there and spin but nothing. It will not pull start and the spark plug is dry. I have been doing enough reading on here to know that I need to check the battery voltage, ETC Throttle adjustment when I get home. Any other suggestions will gladly be accepted. And it really is my girlfriends 4-wheeler, I'm a Mustang kind of guy!
Old Nov 2, 2009 | 02:30 PM
tw1st3d1's Avatar
Start with the basics, does it have spark, If not check fuses, CDI box, coil. If it has spark, does it have fuel? check shutoff petcock, gas in tank, gas thru filter, gas at carb (or injector) These are the basic starting points for all internal combustion engines.
Old Nov 2, 2009 | 06:00 PM
rgwetz's Avatar
Default 500 scrambler
my scrambler didn't want to start so they adjusted the valves and now it starts like new
Old Nov 3, 2009 | 06:45 AM
Kerbbirds's Avatar
can you here the fuel pump cycling when you turn the key on?
Old Nov 3, 2009 | 07:10 AM
08SPORTER's Avatar
OK here's the latest. I am getting spark and I was able to get it running by shooting some starter fluid into the throttle body. It clearly is not getting fuel though. Took the fuel filter off and it was fine and the fuel in it was clean. The fuel lines that I took off did not appear to have any type of pressure in them. So I'm thinking maybe bad Fuel Pump, clogged fuel line somewhere? I would like to see if the pump is getting power maybe a bad fuse? Does this thing have a FUSE BOX? Where is it?? and I am assuming without taking the plastic off yet that the Fuel Pump is located somewhere near the fuel tank? I will check again tonight and see if the fuel pump is cycling on though. The only thing I can really here cycling is the TPS.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
Dylan.11
Utility ATVs
Jun 4, 2015 03:58 PM
1000gade
May 27, 2015 12:37 PM
