110 Mimi Quad Suspension Lube
Old Nov 10, 2009 | 09:06 AM
nimadd's Avatar
Default 110 Mimi Quad Suspension Lube
Hi again all; here’s my next neubee question. Pullin the carb this past Sunday gave me a chance to look things over pretty good after it’s had a couple of hours of run time. I was pleased to see that most of the nuts were nylock lock nuts and those that weren’t were castle nuts with cotter pins. I noticed there was no grease on any of the tie rod ends, a-arm pivots, or the swing arm pivot. Should there be and if so what should I use, lithium grease or axel grease?
Old Nov 10, 2009 | 02:42 PM
nimadd's Avatar
OK I just read over rev's post. Zerks on everything and let the grease flow.
Old Nov 11, 2009 | 07:51 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Quads and dirt bikes from Japan dont come new with a lot of grease on their pivot points either...I use a waterproof/marine grease on my toys. A little insight to Chinese nyloc nuts...like everything else on a Chinese ATV, they only look the part...might work if you dont ever take the nut off...if you ever take it off, use blue loctite..
Old Nov 11, 2009 | 10:18 AM
nimadd's Avatar
Thanks for the warning on the nylocs mywifesquad, when I do the zerks I'll replace with new.
Here in Southern Maryland most of the water is brackish so it’s marine grease on everything boat, boat trailer, car, truck, motorcycle, lawnmower, weed wackier, anything that doesn’t take lithium. I just buy the bug tub of it.
Hay your all over this forum and doin a great job too. Thanks again.
Old Nov 17, 2009 | 09:29 AM
KTM Patrol
Former Chinese POW!
Either that or just use a dab of blue loctite..
Really cant go wrong with waterproof/marine grease...What do you lube on your weed wacker?
Your Welcome and thanks for the compliment.
Old Nov 17, 2009 | 11:56 AM
nimadd's Avatar
What do I lube on my weed wacker? The shaft between the engine and head of corse.
Keep up the great work; It's much appreciated.
Old Nov 17, 2009 | 03:30 PM
KTM Patrol
Former Chinese POW!
I have never even taken my weed wacker apart...did yours sieze?
Your Very Welcome.
Old Nov 18, 2009 | 03:35 AM
nimadd's Avatar
No; I've got an old Homelight I bought at a yard sale 25 years ago. As you can imagine I've been through a few trimmer heads. As long as I've got it apart that far I pull, clean and grease the shaft
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
user493
Aug 13, 2015 12:54 PM
Jul 21, 2015 03:03 PM
