scrambler 500 rear axel removal problems
Old Jan 15, 2010 | 03:37 PM
stonesuperman's Avatar
Default scrambler 500 rear axel removal problems
trying to replace bearings in the rear axel of a 1999 polaris scrambler and having problems removing either the sprocket side hub assymbly or the brake side hub assymbly. i took the outer snap ring off and from what other threads have said just slide off either hub assembly and work on the axel nuts that they slide over but i'm having probs cus i'm not able to fit a puller to either hub and pounded the crap out of it and still nothing.. am i missing something???
Old Jan 15, 2010 | 06:21 PM
4getful2's Avatar
if you've gotten the snap ring off . you'll need to use a chisel or something to get behind the aluminum nut covers(where the foam gasket is) and push them off.use plenty of penetrating oil. The axle nuts are mot likely rusted in place also so use a bunch more pen.oil and start wrenching them off. if you don't have wrenches large enough for the nuts,use pipe wrenches.
Old Jan 15, 2010 | 09:46 PM
ftwflh's Avatar
Cut the axle nuts off and replace
Old Jan 16, 2010 | 04:35 PM
ahhh.. aluminum covers... lol.. thanks for the info.. now on to the axel nuts.. and will cut and get more if i got problems .. thanks guys
Old Jan 18, 2010 | 09:45 PM
well i got it all apart and i have the new bearing races installed.. but when all the parts came in the manual i ordered is on back order.. i know i just can't re-assmyble and just tighten the axle nuts.. is there a procedure and torque spec for the axle nuts??
Old Jan 19, 2010 | 05:54 AM
ftwflh's Avatar
Use plenty of thread dope and tighten where there is no play.
Old Jan 19, 2010 | 09:24 AM
dope as in RED LOCTITE, or pipe dope?
Old Jan 19, 2010 | 06:10 PM
ftwflh's Avatar
NO!!!!!!!!!!!! I was meaning never seize or Copper Koat
Old Jan 19, 2010 | 07:35 PM
4getful2's Avatar
with red, he'll never be able to get it apart next time. the threads rust up enough on there own.
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
blaze_master
May 26, 2015 11:18 AM
Biggieshortie89
May 26, 2015 08:01 AM
