Starting question
Old Feb 9, 2010 | 05:14 AM
fowler5084's Avatar
Default Starting question
On my kids 90cc jetmoto I think its an 06' model. While I'm pushing the start button and its turning over if I try to feather the throttle it will cause the starter to disengage with a loud snapping noise. It will start but I have to wait for it to begin to fire and let off the starter button and then give it gas. Has anyone ever had this issue with one of these chinese bikes or any bike for that matter?
Old Feb 9, 2010 | 10:50 PM
LynnEdwards's Avatar
Electrical Expert
Have you ever adjusted the valves? They require periodic adjustment. They tighten up with wear, and tighten even more when cold. So the first symptom is starting when cold.
Old Feb 10, 2010 | 09:48 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I dragged my 90cc utility off the shelf and tried to start it while feathering the throttle... It would stop turning over or turn over much slower but the starter never kicked out.. As long as you can get it running I wouldnt sweat it..
Old Feb 10, 2010 | 01:02 PM
fowler5084's Avatar
Thanks for the replies. I will look into the valves since I have never adjusted them. The question is what kills me though, because although I can get it started I don't see or understand how feathering the throttle while turning it over would cause the starter to disengage since the throttle appears to be mechanical whereas the starter is on the electrical side of the house unless there is something I am not seeing.
Old Feb 10, 2010 | 01:38 PM
KTM Patrol
Former Chinese POW!
The only thing I can think of is the starter is getting weak.So as you feather the throttle more fuel enters the cylinder and creates enough compression to kick out the starter...
Im guessing it didnt do this before? Or have you just started feathering the throttle on start up recently?
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
kwackermann
Jun 24, 2015 10:18 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
