05 600 sportsman accessory plug
my accessory plug on light pod not working do i have fuses also have dual red with white stripe wires under front light pod cover comeing from harness dont no what they go to. also a three hole plug in same location open with nothing to plug to any suggestions thanks.
Fishey, I have 2004.5 600 and the repair manual shows a brown and red wire going to the accessory plug. It shows a 10 amp fuse on the red wire. Check to see if the spade connector is just loose, that happened to me. As far as the two red/white striped wires, manual says "ACC #2 located below head lamps". I have know idea exactly what it is for though. Hope this helps you.
This connector works for many ATV's to plug in whatever you want.
Just cut it in half and you have 2 pigtails.
Available at parts house or truckstops
Grote Industries: Trailer Connectors (Product #82-1034)
the white plug with the 3 wires if for troble shooting the speedo.
KimSJoh
14
Jul 18, 2015 07:20 PM
