Charging new battery
Old Apr 16, 2010 | 02:41 PM
bweymouth's Avatar
Default Charging new battery
I just bought a new Yuasa battery for my sons Polaris Sportsman 90. I added the acid and put it in the quad. I turned over great and started right up. Do I need to charge the battery right away after adding the acid? If so, for how long?
Old Apr 16, 2010 | 02:45 PM
Jaster94's Avatar
the box the battery comes in should have a chart in there to give you the times. the last time i bought a battery, it told me about 4 hrs. i haven't looked back since on my batteries. hope this helps!
Old Apr 16, 2010 | 02:52 PM
Jaster94's Avatar
you may check with the dealer you bought it from unless you find the paperwork. i'm thinking you may not want to go more than 2 amps while charging for 4 hrs.
Old Apr 16, 2010 | 04:31 PM
bentarrow's Avatar
First Things First!
If your charger goes as low as 2 amps that would be best, if you don't have any way of telling the volts or a charger with automatic shut off be careful not to boil off acid. Full charge should be around 12.8 volts after it sits for an hour after charging.
Old Apr 16, 2010 | 04:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should have let your battery set about 30 minutes after adding the acid to soak into the plates then charge it for say 8 hours on a slow charge like around 2 amps for the best life of the battery. imo
Old Apr 16, 2010 | 11:27 PM
chuck_raduenz's Avatar
agreed shoulda let it set. then top it off to the marks. chage at a slow rate for least 8hrs. then put it in.
Old Apr 17, 2010 | 12:38 AM
Spdecat's Avatar
Look into to the The smartest battery chargers in the world, by CTEK Power INC.
Old Jul 15, 2010 | 04:53 PM
Spdecat's Avatar
Originally Posted by Spdecat
If you live in Canada , Canadian Tire has the CTEK charger on sale 40% off next week .
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
momma's bike
Aug 6, 2015 09:49 AM
