Sportsman X2 front springs????
Old Apr 18, 2010 | 03:55 PM
DELUX500EFI's Avatar
BUY AMERICAN!
Default Sportsman X2 front springs????
I know the Sportsman X2 have a different part # than regular Sportsman. But are they interchangerable???(front springs)...Have a friend with a 800 X2 looking for heavier front spring..Thanks for any help..
Old Apr 18, 2010 | 04:25 PM
NoJoke's Avatar
Howdy DELUX500EFI............I replaced my front springs on my 07 X2 with the Polaris HD springs (#2876153). The front started to sag and the HD's brought it back to snuff.......a firmer ride and much better in cornering and no bottoming out when the front hits a dip.....don't know about the interchange part of your question......are you looking to use your buds springs if he gets the new HD springs?......NoJoke
Old Apr 18, 2010 | 05:36 PM
Did the same thing as NoJoke. I ordered the Polaris HD front springs and it is a great improvement in steering, cornering, going down hills (no bottoming out), etc.
Old Apr 18, 2010 | 06:56 PM
BUY AMERICAN!
Smile
Thanks..My friend will be ordering them tommorrow..We will not be using the stock springs .I now ride a 550 XP...
Old Apr 18, 2010 | 07:32 PM
williamk's Avatar
Is it as hard to change the front springs as the rear? My buddy had a hard time with the rear
Old Apr 19, 2010 | 10:36 AM
NoJoke's Avatar
The replacing of the front springs was rather easy. Check out the Stendori Sticky on CV Joint Removal Guide.......this will help on front springs replacement...........Have fun and good luck......NoJoke
Old Apr 19, 2010 | 03:18 PM
NoJoke's Avatar
Whoa!!!!.....the last post of mine had the wrong sticky.....it's the Homemade Spring Spacer sticky that shows the front springs and such.....NoJoke
Old Apr 19, 2010 | 03:28 PM
You basically have to take the front rack/storage bin off. This gives you access to the tops of the shock towers. Lift the front end just enough to get the tire off the ground. Undo the bolt on the top using an open or closed end wrench on the nut and a socket or wrench (I think 3/8") on the top of the strut. Carefully take off old springs and reverse the process for the new ones. Don't jack it any higher than you need to go. I think the ball joints or something can get messed up.
Old Apr 19, 2010 | 03:34 PM
Big600twin's Avatar
It's not the ball joints that get meesed up it is that the CV joint can get seperated. OH yeah,....I found out the hard way. I would look into the EPI springs as well. I just did mine a few weeks ago and they work great and they were cheaper than the Polaris HD.
Old Apr 19, 2010 | 05:09 PM
Thanks for the correction Big600. I wasn't sure on what would get harmed.
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
Mphillips
Jun 26, 2015 03:52 PM
SaMs0nOLD
Feb 2, 2000 11:43 PM
