Suzuki lt 80 help wanted
Old Apr 25, 2010 | 04:32 AM
CornwallQuad's Avatar
Default Suzuki lt 80 help wanted
Hi All
I have purchased a lt 80 (I think 2005) which has never worked properly. It is now not working at all and my dad who is mechanically minded is very frustrated.
The starter motor has been replaced but the splines on the commutator and gear have worn within weeks so that it is not engaging. This is the second starter motor with the same problem. Is this a common fault?
The fuel doesn't appear to get into the engine as the spark plug is dry when checked. The fuel is getting into the carb and the float is fine and the jets are clean. Any suggestion?
Previously it was running but died after 15 minutes and would not re-start so was guessing the coil may be at fault.
Any comments / suggestions would be gratefully received.
Old Apr 25, 2010 | 09:45 AM
LT80's Avatar
LT80 Expert
The starter issue is strange. Deff not common.
Fuel: try hand choking it (2 fingers in front of carb.
I'd do a compression test. That may explain alot.
Nondem
Feb 22, 2020 12:20 PM
NatePerz
Jul 27, 2015 03:27 AM
jaime511
Jul 19, 2015 01:58 PM
Jul 15, 2015 02:07 AM
clsharky
Jul 13, 2015 02:07 PM
