XP Skid plates
Old Jun 21, 2010 | 08:41 PM
FunRide's Avatar
Default XP Skid plates
I know this has been discussed before, but just wanted a refresher on what the latest opinions are for XP skidplates. I pounded my machine a couple of times the other day, once above water and once below....major impacts I could feel all the way through my body....Frankly I'm afraid to look, but will haul the beast up tomorrow and inspect the damage. It's fairly obvious now that I need a better skid plate...what are my options if I don't want to spend $600 for the full aluminum deal.
What I find strange is that aluminum is super sticky...it grips to rocks like glue. My first pair of waders had aluminum soles for walking on wet rocks while fly fishing. I could almost run down a slippery rock river that you'd be on your a$$ on with sneakers. -You'd think there would be a better substance than aluminum for a skid plate that's making contact with rocks...It's light, and durable and relatively inexpensive to buy/fab.....Maybe some kind of slippery plastic would be better and cheaper?
Old Jun 22, 2010 | 07:01 PM
Tundra27's Avatar
Lots of money for a plate and the bike already has pretty decent protection underneath. Nicks and scratches I don't mind and the essential parts are protected. Probably cheaper to replace a bent or broken part in the long run than the cost of full plating. My thoughts... Although I beat the heck out of my bike and don't give it a second thought.
Old Jun 22, 2010 | 08:25 PM
850 trailrider's Avatar
Default xp skids
I wouldnt give 50 cents for the plastic skids on my xp Put on ricochet full set and very happy with ,you can get a full set or just get what you need and get other parts of set if you feel you need it richochet well thought out good hardware pkg and hd quality plastic skids on mine were torn and plenty of mud above so cleaning the mud out once in a while is an issue with each I believe IMO
Old Jun 26, 2010 | 04:35 PM
FunRide's Avatar
How difficult are the Ricochet's to get off in the winter? I need to mount a plow....Doesn't look like fun to be taking on and off on a semi-annual basis.
Old Jun 27, 2010 | 11:26 AM
Default xp skid plates
Not sure how plow mounts up ,maybe have to just remove front skid? but they recomend removing skids every so often to clean out, neversieze on bolts? might make removing not so tuff
lonerider856
Oct 13, 2023 03:45 PM
Alex G.
Sep 11, 2017 11:38 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
