03 sportman 700 odometer problem
Old Jul 24, 2010 | 10:43 PM
saxonj's Avatar
Default 03 sportman 700 odometer problem
My old Odomiter got moisture in it and slowly quit working. I ordered a new one and installed it and it will just show a E 0. I know the sensors are good
Old Jul 25, 2010 | 09:37 AM
TLC's Avatar
TLC
Does your AWD still work? you need a working speedo for the AWD to work.
Old Jul 25, 2010 | 10:45 AM
saxonj's Avatar
I have not tried it yet but nothing else will show on the speedo I am not sure if it needs to be programed or should I just plug it in and it work
Old Jul 25, 2010 | 11:00 AM
TLC's Avatar
TLC
To test the AWD,just nose up to a tree or solid wall in low range 4wd , if the rear wheels break lose only then the awd is not working due to the speedo not working.
Old Jul 26, 2010 | 07:03 PM
saxonj's Avatar
No the AWD douse not work
Old Jul 27, 2010 | 08:44 AM
TLC's Avatar
TLC
Only two option,buy another speedo ($300 plus) or do the AWD wirring bypass trick. Do a search on this site about it. The ATV will have a normal working AWD even without a speedo,many people have done it. Its what I will do when the time comes,the speedo sure does not give me $300 worth ot info.
That was a dump move when Polaris made the speedo a component of the AWD back in 2000.
Old Jul 28, 2010 | 12:20 PM
Big600twin's Avatar
As long as you feel the install was done correctly, I would try and exchange for a different speedo. If it was new and doesn't work you should be able to get a new one...
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
