YFM 80N Timing Mark help
Old Aug 11, 2010 | 09:46 PM
Skullion's Avatar
Default YFM 80N Timing Mark help
Not sure what year 85? Badger Moto4.
Honed cylinder and installed new rings. Won't start wondering about timing. I can see a mark on the head for the cam gear but can't see one for the crank. No this one does not have a rubber cap in the cover. I had to take the cover of and I can see a mark on the flywheel but not on the case. It looks like there are 2 small notches in either side of one of the bolt holes just above the pickup coil but I'm not sure if these are it nor which one if it is these.
On the flywheel there is a T followed by a line and then what appears to be a H or just 2 lines close together. (ll)
Yes this thing ran fine before this rebuild except for low comp and burned a little oil.
Still have spark and have fuel.
Old Aug 12, 2010 | 10:53 AM
hillbilly_racer's Avatar
If I remember right, there should be a triangle shaped piece made into the main case. This should line up with your T mark. To be sure, you can always check for tdc the spark plug removed.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
