changing the spark plug on a 2005 KFX 400
Old Sep 3, 2010 | 04:01 PM
Pizzle's Avatar
Default changing the spark plug on a 2005 KFX 400
I just picked up a used KFX 400 and am not familiar with this bike. To all you experts out there I have a question. Do you have to take off the gas tank to change the spark plug? My bike needs a new plug. I don't know why kawasaki put the plug in such a tight space. Any help I would appreciate.
Pizzle
Old Sep 9, 2010 | 11:25 AM
Dirtjunkie85's Avatar
It can be done with the tank on but it is a huge pain and by the time you get it changed you might as well have took the tank off, keep in mind though if you have a buddy just hold the tank up a little after you have loosened all the bolts you dont have to remove the tank completly, it really dont take long and is pretty easy.
Old Sep 9, 2010 | 03:52 PM
Scooter86's Avatar
Knows Old ATV Questions!
Pizzle
Ah, one of the penalties of a high performance dohc motor is the plug gets buried and access is tight. Luckily they don't need new plugs often.
Old Sep 12, 2010 | 08:11 PM
NewRide's Avatar
Default Takin out the plug
If you have a socket wrench with pivot head it's pretty easy I also use one of those telescoping magnetic tools to pull plug once its loose. Hey I tried to post up if anyone knows the factory setting for the idle screw how many turns out, do you happen to know pizzle? Thanks
Jmuddin284
Jan 19, 2026 07:16 AM
lightninboy
May 16, 2021 09:52 PM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
