CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Ds 650 problem
Old Nov 21, 2010 | 10:59 AM
goosefrauba's Avatar
Default Ds 650 problem
Hello my moto friends, I'm new to the ds 650 and just finished rebuilding the motor top to bottom, pretty sweet engine, however I cant get it to start for the life of me.The stator wires and trigger coil wires where melted by the exhaust and so on. Anyway, I set the cams with the tdc bolt, adjusted the valves to spec and all I get when cranking is a big backfire back through the mouth of the carb. I checked the spark and it has solid consistant spark on both plugs. Check the voltage from the trigger coil as per manual and it was less than spec so I replaced it and spaced it off the flywheel like the manual said. Now I have solid spark and the compression cold is around 110 psi. I've been through the carb twice and the jets are all clean. I'm really at a loss because I have all the basic elements for this thing to run. (gas, fire, compression, air) Is it possible to have spark and yet have a faulty cdi or ecu? any ideas fellas?
Old Nov 21, 2010 | 01:55 PM
justme23005's Avatar
Your cams are off... Re-check the tdc bolt..
Old Nov 22, 2010 | 05:59 AM
Thanks for the response brother, I'm headed to the shop this morning and will check the cams again. Do you know if there is a specific cam chain pin count between sprockets like there is on the suzuki's?
Old Nov 22, 2010 | 10:49 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
There are markings (lines) on the cam sprockets and markings on the plastic cahin rider that need to be lined up. Alot of times they can look to be right on but might be a tooth off. Adjust them with the tensioner in so that it doesn't rotate off when you reinstall it.
What were your gap settings? Did you put the key back in for the flywheel? If it slips at all you will get an ill running machine...
Old Nov 22, 2010 | 02:39 PM
Alright, here's what we have.. I installed the tdc bolt to lock the crank, checked the cam timing with the pointers on the black cam chain block & their good. I set the plug gap to .65mm and re-checked valve clearance & their in spec. .15mm is good .16mm is to much & still, all I get is an ocassional pop through the carb. I hit it with a little either and she wanted to run for about 3 seconds and back to popping out the carb. is it possable the cdi is bad even though I still have spark? or is there a specific fuel screw setting? all the book said was at least 1 turn out.
Old Nov 24, 2010 | 12:19 AM
aceisback's Avatar
Military Rider
".15mm is good .16mm is to much"
Where is it that you got this information? The correct gap settings are between .004 to .006.
Old Nov 25, 2010 | 12:26 PM
bigned1904's Avatar
this guy knows his ****, btw whats up dude i think i met u out at glamis halloween 09. your seth and tracys friend right?
Old Nov 25, 2010 | 10:05 PM
aceisback's Avatar
Military Rider
Yep, that was me. Grenaded transmission on the F-350, not alot of riding that trip! Heading that way first thing in the morning. Taking my son down there for his first trip of the season. Well since Labor Day up at St. Anthony for him anyway.
Old Nov 25, 2010 | 10:24 PM
bigned1904's Avatar
thought so this is kevin the big guy that was out there, im headed out in the am as well.
Old Nov 26, 2010 | 07:01 PM
Sorry bro, might have had turkey on my mind.. I'll have to check the book again. I pulled them of the top of my head.. might of had them confused with another unit.
gonna give it another look on monday..
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
