Lt 80 uni airfilter idle fast
Old Nov 28, 2010 | 11:31 AM
fourbunches's Avatar
Default Lt 80 uni airfilter idle fast
I have a 2002 LT 80 completely stock. I replaced the stock air filter with a UNI foam air filter. Now the idle is high and the ATV will not sit still on its own at idle. Is there an idle adjustment somewhere? Do I need to replace a jet? If so which one and what size would be recommended for a stock unit with a UNI air filter? Thanks for your help!
Old Nov 29, 2010 | 09:29 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
The idle adjustment is the screw on the side. It's the only screw so there can be no mistake.
I recommend a 90 main jet for all as they (LT/KFX80's) are jetted fat from the factory.
I don't feel that the air filter alone shold cause this. Sometimes the throttle cable gets yanked on and causes a high rpm. Also check the throttle cable adjustment on the top of the carb. too tight can cause high rpm.
Old Nov 30, 2010 | 07:10 AM
scootergptx's Avatar
Supersock
Hired Gun!
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
