87 LT80 transmission problems
Old Dec 28, 2010 | 03:55 PM
Iman's Avatar
Default 87 LT80 transmission problems
I read the forums alot but i think this is my first time posting. My son was riding through some puddles and got the KN air filter soaked..... it bogged down and would not move, would run(not go forward) but bogging down. Cleaned up and dried the air cleaner and motor sounded right but still would barely go forward, in the meantime a friend of mine put 3/4 a quart of oil in the clutch caseing and drenched everything with oil.... So I took off the side cover, cleaned out all the oil, cleaned all the gunk in the rollers on the front clutch, cleaned up the belt, thought i got any water or oil out but when i put it back together still had the same problem
Old Dec 28, 2010 | 05:38 PM
LT80's Avatar
LT80 Expert
Did you clean the carb? I suspect a plugged jet/orfice/etc.
Old Dec 28, 2010 | 06:49 PM
Iman's Avatar
As usual you were right..... Thats usually the problem with that KN filter 99.99% of the time, I had cleaned it once but suspect I either missed some dirt or like the second time I did it i left choke up after re installing carb= no power. Anyways thanks a million and at least now I have some knowledge on how the clutches work
Captjay
Jul 23, 2015 12:33 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
Wnthunting
Jul 9, 2015 03:02 PM
bikedad3
Jul 2, 2015 02:15 AM
