awd problem still
Old Jan 1, 2011 | 05:47 PM
jerdel6918's Avatar
Default awd problem still
So I've flushed my front hub and I've taken it all apart I've even changed the armature plate... so just now I jacked it up and spun the tires and noticed that I'll spin but has no tork I can stop it with my hand... is there anthing else I should look at besides the magnet?
Old Jan 1, 2011 | 05:54 PM
Kerbbirds's Avatar
what year a nd what machine?
Old Jan 1, 2011 | 06:29 PM
jerdel6918's Avatar
Its a 02 sportsman 500
Old Jan 1, 2011 | 07:06 PM
jerdel6918's Avatar
What's the diameter of the roller suppost to be... I have a thought
Old Jan 2, 2011 | 08:22 AM
Kerbbirds's Avatar
take the hub apart and see if magnet holds the armature plate when awd is swiched on, should really stick to the magnet , should be very hard to remove plate if not need to make sure there is 12 volts at plug in for hub wires under front cover, follow wires to the magnet and make sure they arent broken anywhere,
Old Jan 2, 2011 | 12:07 PM
jerdel6918's Avatar
Ya I checked that and it holds really well
Old Jan 2, 2011 | 01:19 PM
Polarat's Avatar
If the surface of the rollers looks good, what about the internal surface of the hub where the rollers ride? Does the garter springs look good? Not stretched out? Check the gap of the coil. I think it should be 0 to .001 in.
Old Jan 2, 2011 | 04:04 PM
jerdel6918's Avatar
I checked everything... the inner hub is smooth and shiny... I will just have to take the other side off and see what the difference is... it just take it in and get someone to look at it for me
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
