05 Trailboss No Reverse
Old Jan 20, 2011 | 04:44 PM
tonythom's Avatar
Default 05 Trailboss No Reverse
I just picked up a used trailboss. It will shift from Forward to nuetral, Shifts in reverse and the reverse limiter kicks in and makes the bike stutter if you give it gas. Problem is no reverse, no grinding, no noise, simply like it is in neutral. Any ideas, I know maybe shifting fork but it works good F to N. Thanks TonyT
Old Jan 20, 2011 | 06:09 PM
ftwflh's Avatar
That transmission has a known problem of popping the snap ring off the reverse gear.I fix them by taking the tranny apart adding a shim to take up play on the shaft and using a new snap ring.Some just tack weld the snap ring in place
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
Myronh
Sep 8, 2015 11:27 AM
