Starter removal in an 06 Sportsman 500 HO
HI can anyone give me a step by procedure for removing the starter. I have to change mine out. It won't engage as soon as the temperature drops below freezing. Which in Winnipeg is from October to May.
Thanks
Doug
Thanks
Doug
diconect the negative battery cable at the battery and at the starter, remove the 2 bolts in the starter, remove starter, I would remove the recoil housing and have a look in ther too, maybe full of watweer, mud ect may be your problem
Hold it! Before you pull the starter. Is the starter winding up when you hit the key? If it is, I would strongly suspect it's the bendix not kicking out when spun by the starter motor. If this is your case, no need to pull the starter just yet. I'd pull the recoil housing as keybirds mentioned before and inspect everything. Pay careful attention to the bendix. That's where I've seen most problems when the starter motor is spinning but not turning the engine over.
Thanks guys, I will take a look a the recoil. I had tried to pull it over manually the last time the starter would not engage and the recoil rope would not pull out. This starter problem only started when it got cold out, but I had been riding through alot of water and crap. I just need it too warm up a liitle, -30C is too cold to work in teh garage.
Doug
Doug
If water is in the recoil ,the Bendix will not work until its thawed out. Just let the ATV sit in a heated garage or but a torch on the recoil cover and see if it starts. Unless you silcone the pull rope handle down over the rope hole water will always work itself into the recoil.
If you ever have to change the starter, remove it from uder the seat and air box, not the manuals hard way of removing the clutches and back plate.
Thanks TLC, The polaris service manual I have doesn't even talk about removing the starter. When I looked at trying to take it out I figured I was going to have to take out the air box, I wasn't quite sure how I was going to get at the bottom bolt behind the clutch cover.
Doug
Doug
KimSJoh
14
Jul 18, 2015 07:20 PM
