Starter removal in an 06 Sportsman 500 HO
Old Feb 8, 2011 | 01:09 PM
dslyone's Avatar
Default Starter removal in an 06 Sportsman 500 HO
HI can anyone give me a step by procedure for removing the starter. I have to change mine out. It won't engage as soon as the temperature drops below freezing. Which in Winnipeg is from October to May.
Thanks
Doug
Old Feb 8, 2011 | 08:53 PM
Kerbbirds's Avatar
diconect the negative battery cable at the battery and at the starter, remove the 2 bolts in the starter, remove starter, I would remove the recoil housing and have a look in ther too, maybe full of watweer, mud ect may be your problem
Old Feb 8, 2011 | 11:06 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Hold it! Before you pull the starter. Is the starter winding up when you hit the key? If it is, I would strongly suspect it's the bendix not kicking out when spun by the starter motor. If this is your case, no need to pull the starter just yet. I'd pull the recoil housing as keybirds mentioned before and inspect everything. Pay careful attention to the bendix. That's where I've seen most problems when the starter motor is spinning but not turning the engine over.
Old Feb 9, 2011 | 08:22 AM
dslyone's Avatar
Thanks guys, I will take a look a the recoil. I had tried to pull it over manually the last time the starter would not engage and the recoil rope would not pull out. This starter problem only started when it got cold out, but I had been riding through alot of water and crap. I just need it too warm up a liitle, -30C is too cold to work in teh garage.
Doug
Old Feb 9, 2011 | 09:11 AM
TLC's Avatar
TLC
If water is in the recoil ,the Bendix will not work until its thawed out. Just let the ATV sit in a heated garage or but a torch on the recoil cover and see if it starts. Unless you silcone the pull rope handle down over the rope hole water will always work itself into the recoil.
If you ever have to change the starter, remove it from uder the seat and air box, not the manuals hard way of removing the clutches and back plate.
Old Feb 9, 2011 | 10:29 AM
dslyone's Avatar
Thanks TLC, The polaris service manual I have doesn't even talk about removing the starter. When I looked at trying to take it out I figured I was going to have to take out the air box, I wasn't quite sure how I was going to get at the bottom bolt behind the clutch cover.
Old Feb 9, 2011 | 12:00 PM
Doug
Yep, definitely sounds like water in the recoil housing. Hope the water didn't damage any of the electrical components. When you put it back together I'd seal the handle with silicon real good to help prevent this from happening again. In the event you'd have to use the pull start just reseal it again and your good to go.
Old Feb 11, 2011 | 10:01 AM
TLC's Avatar
TLC
The Hard core mud runner guys at High Lifter forum actually remover the pull rope assembly, and plug the pull rope hole off.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
