Major Electrical Issue-Help PLZ
Old Feb 18, 2011 | 10:16 PM
sohi44's Avatar
Default Major Electrical Issue-Help PLZ
I have a 1987 Bayou 300 2x4. i recently acquired this quad not running, I am hoping I can get some assistance with the issue. following is a list of new parts recently installed.
new battery
rebuilt engine
new key switch
with battery charged and key in run position I have no dash lights as well as no crank. it seems as tho the whole thing is " Dead " i'm not very quick when it comes to electrical diagnosis any help would be greatly appreciated. Thank you
Old Feb 19, 2011 | 09:25 AM
snow racer's Avatar
Check the fuse it always happins
Old Feb 19, 2011 | 12:37 PM
sohi44's Avatar
I have and fuse is good, put a meter on it.
Old Feb 19, 2011 | 12:40 PM
sohi44's Avatar
Thanks for the tip though
Old Feb 19, 2011 | 04:38 PM
snow racer's Avatar
Im not fimilar with thees bikes so sorry i cant help
Old Feb 19, 2011 | 05:04 PM
sohi44's Avatar
Thank you anyway I appreciate any help I can get.
Old Feb 19, 2011 | 07:20 PM
Kerbbirds's Avatar
start at the battery with a multi meter, check connections then go to the selenoid , take wires off and check the nuts under the cables for corrosion and tightness, follow to the starter and check connections, may have to follow eveery wire and check every connection., it should have a fusible link somewhere, usually wrapped in a plastcs pouch oe cover
Old Feb 19, 2011 | 08:59 PM
sohi44's Avatar
Thank you, I will give that a shot n see what happens.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
