Sportsman 500HO
Old Apr 7, 2011 | 08:37 AM
mudder121's Avatar
Default Sportsman 500HO
I have a 04 sportsman 500ho, the problem is it shuts off after running for a few seconds with the key on (no cluster display, no lights). I can turn the key off then back on and the same thing happens. Iv been thru all the wiring and all looks good. Any advice?
Old Apr 7, 2011 | 09:04 AM
Spdecat's Avatar
If your charging system is not working your bike has been running off the battery . Now the battery no longer has enough power to keep the machine going . After sitting you might get power for a few seconds but then she'll go dead . Check charging system , check battery , check all battery connections .
Old Apr 7, 2011 | 09:46 AM
mudder121's Avatar
Will give that a try, battery seams ok but will have it tested
Old Apr 7, 2011 | 09:51 AM
TLC's Avatar
TLC
Not shure how your H.O is different but I ran mine for a month with a dead battery ,just pull start and go before I got around to getting a new battery.
Does the later carbed H.Os have a ECM like the EFI models and if so did it get the recall done?
Old Apr 7, 2011 | 11:36 AM
miniexcavator's Avatar
I had this problem and replaced the battery and it cured it (2004 sportsman 500 ho)
Jmuddin284
Jan 19, 2026 07:16 AM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
79hugger
Aug 30, 2015 02:21 PM
pro94lt
Aug 20, 2015 10:02 AM
