400 ho clutch ?????
Old May 4, 2011 | 10:03 AM
xerilious's Avatar
Default 400 ho clutch ?????
Was wandering if anyone could tell me or give me a website that I can find the demensions of the clutch springs and rollers and what not for my 2010 sportsman ho so i can get a clutch kit set up.
Old May 4, 2011 | 11:54 AM
canamxtra's Avatar
I think the only thing you can change are the rollers and that is for altitude only. There are no springs.
2009*****SPORTSMAN-400-HO-4X4*****A09LH46AQ-AX-AZ****|****DRIVE-TRAIN--PRIMARY-CLUTCH*****A09LH46AQ-AX-AZ
Old May 4, 2011 | 12:19 PM
xerilious's Avatar
maybe I misunderstood him he said the wachs or something like that beacuse it does not have a primary and secondary like the usual polaris has ??
Old May 4, 2011 | 03:29 PM
On the 2010 400 the clutches are made by AEON they are not the standard clutches that are used on other Polaris atvs. Not sure what mods can be done to this assembly if any? OPT
Old May 4, 2011 | 04:21 PM
TLC's Avatar
TLC
Wow never knew that they make cluches without a spring.
Old May 4, 2011 | 05:45 PM
YEP, there quite a bit different! I tore into a one checking for excessive noise. Nut had backed off and amplified the noise through the metal clutch cover. OPT
Old May 6, 2011 | 08:39 AM
EPIChad's Avatar
They use a clutch system similar to Arctic Cat and Suzuki. I havent had one apart to see if the springs and weights are the same as the those brands though.
Old May 6, 2011 | 09:18 AM
TLC's Avatar
TLC
That what we are talking about ,the clutches have no springs whats so ever which is really different . Not sure if its a improvement or cost saving idea.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
