09 kawasaki prairie belt indicator light
Old May 21, 2011 | 10:15 AM
damon's Avatar
Default 09 kawasaki prairie belt indicator light
How do you reset the belt indicator light on a 2009 kawasaki prairie 360? It has come on for the 100 hour use.
Old May 23, 2011 | 08:52 PM
bruteforce65006's Avatar
lift seat
find fuse link
black n gray connectors
unplug connectors
connect black to gray n gray to black
turn ignition switch on
there will be a series of blinks
let this happen for 45 seconds or so
this will reset light
turn off ignition switch and reconnect wires to their original place.
check your belt..........
Old May 23, 2011 | 09:07 PM
dondeere's Avatar
I would inspect the belt! I have seen many wore out belts at 100 hours.
Old May 24, 2011 | 03:15 PM
Hayashi's Avatar
Yes, make sure you check the belt for wear/tear and deflection as well. It came on for a reason.
Old May 24, 2011 | 11:00 PM
damon's Avatar
Thanks for the info I will check the belt
Old May 25, 2011 | 07:25 AM
TLC's Avatar
TLC
Most likly the belt is fine with only 100 hrs, that light goes off to tell you to check the belt,I aways thought it was a dumb idea, it like having a warning light telling you to check your spark plug and air filter or change your oil when its just common sense.
Old May 25, 2011 | 09:41 AM
Hayashi's Avatar
The thing is there are some folks w/o common sense.
Belt wear is totally depending on how the vehicle is driven/used. It can be totally fine or totally worn out at 100 hrs. It's like brakes on your car.
Old Jun 2, 2011 | 11:27 AM
dilogdp's Avatar
Default belt reset
I would check the belt but most likely all you need to do is reset the light. As mentioned, it is meant to "go on" at 100 hours.
The service manual illustrates the process. I can provide the process, once I get hold of my manual, if you would like the step-by-step process.
Old Jun 3, 2011 | 09:47 AM
Hayashi's Avatar
Originally Posted by bruteforce65006
lift seat
find fuse link
[/IMG]
On Prairie 360, you don't have to remove the seat nor have to find the fuse link. Everything is there and done on the right side of the quad just under/behind the front fender.
slowgsxr97
Mar 18, 2022 03:40 AM
coolguy420
Jul 28, 2015 01:54 AM
DeFox500
Jul 26, 2015 06:32 PM
Schneider
Jul 24, 2015 05:05 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
