85 honda 3 wheeler 250es stalls
Old Jul 2, 2011 | 09:44 AM
HONDALIFE's Avatar
Default 85 honda 3 wheeler 250es stalls
when i start it it sounds fine but then when i go to drive it it stalls any ideas thank you in advance
Old Jul 2, 2011 | 10:00 AM
sosnocor's Avatar
probably not getting enough gas. which would be a carb problem. did you clean the carbs? check the jets too and make sure they arent plugged. otherwise possibly check the throttle, that it is in there correctly.
and does it stall out if you give it gas while its just sitting there, not in gear?
Old Jul 2, 2011 | 10:10 AM
HONDALIFE's Avatar
yes it does very often but im just affraid i might screw it up even more and yea it stalls often if its not in gear after like 1 min or if i give it gas it will often stall, do you think that would be a fuel problem?
Old Jul 2, 2011 | 10:32 AM
sdm111's Avatar
2 strokes or 4
Try a new spark plug first, it may be fouled and flooding it out when you give it gas. Other than that like the above post it may need a good carb. cleaning.
Old Jul 2, 2011 | 11:17 AM
HONDALIFE's Avatar
thanks for the help the fuel line was clogged
RickyMac
Mar 5, 2016 07:27 AM
momma's bike
Aug 6, 2015 09:49 AM
fire1998
Aug 6, 2015 02:46 AM
mdigitale
Aug 6, 2015 12:35 AM
HondaR24
Jul 16, 2015 10:45 AM
