Carb adjustment question
Old Jul 15, 2011 | 08:57 PM
Jmuddin284's Avatar
Default Carb adjustment question
What part of the throttle does the air screw control on a 2 stroke carb? I'm really close to correct adjustment after a new clampon air filter, and I've played with the air screw before. I just want to know from where to where does it adjust in the range of the throttle. Thanks!
Old Jul 16, 2011 | 05:54 AM
Air/fuel screw controls idle and up to about 1/4 throttle,past that its the main jet and slide needles function primarily.Adjustment range normally between 1 1/2 to 2 1/2 turns depending on engine mods,air filter type,etc. OPT
Old Jul 16, 2011 | 08:30 AM
Jmuddin284's Avatar
That's what I needed Thanks! I know I've read it on here before but I couldn't find it last night and am leaving in a couple hours to ride so I gotta get her to quit that little bit of stumble out of the gate before I leave. Thanks again!
Old Jul 16, 2011 | 08:36 AM
Try shutting the air fuel screw down,even down to 1/2 turn if helps while trying out. If doesn't help,may have to raise needle or go a little larger on the jets. OPT
Old Jul 16, 2011 | 08:14 PM
Jmuddin284's Avatar
I was pretty close as far as the air screw goes, I went up to a 260 instead of a 240 and ended up around 2 turns out on the air screw to get it to where it doesn't studder on take off. I just couldn't remember which part of the throttle range the air screw made a difference in, but it's running like a 400 2-smoke should be now Thanks!
Old Apr 18, 2013 | 01:04 PM
Terry Dejaynes's Avatar
i was trying to get my 2004 330 trail boss to idle its been sitting in someones back yard untill i got it got it started but wont idle help
Old Apr 18, 2013 | 01:23 PM
Trash in the jets are the most common problem not allowing enough fuel to idle.Might be time to clean the carb or install a new carb kit since it's been sitting up. 1003-0159 - ATV Complete Carb Rebuild Kits Polaris Magnum 330, Trail Boss 330 | ATV Parts | MFG Supply
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
JBibb
Jul 4, 2015 10:16 AM
Ty Speece
Jul 2, 2015 04:59 PM
Joe04785
Jun 15, 2015 03:12 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
