00 250 trailblazer
Old Jul 31, 2011 | 01:38 PM
young#1's Avatar
Default 00 250 trailblazer
i have a 2000 polaris tb and having problem wit it. the belt was slipping so call RR and got new botton springs and a new belt. so i install all the parts perloaded the spring set 2 2, the belt still slips just not as bad as before . a nother thang is that its hard to start some thime and some thimes strat sec pull but cuts off when rinding after 30 to 45 mins r so and then relly hard to get back going have to take the air filter off and cover the hole up and pull it over and over . the tb used to idle like a 2 stroke and now when it do idle it kinda like a four stroke idling. it is an 00 so dont know if she is in need of topend rebuild or if it some thang else help is needed !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! oh yeah also got to oil block off kit from Mr RR as well
Old Jul 31, 2011 | 03:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forums. how is the clutch faces them selves? you said you replaced the secondary clutch buttons and 1/3 turn pre loaded the secondary when you put it back together correct? is the belt on so the words are facing you and you can read them? yes some times it does make a differnce. as far running it sounds like the first thing you should do is a compression test to how much cpmression there is. checking when its cold there should be at least 100 psi at the minum. also the carb may need to be cleaned. just a few things to check.
Old Jul 31, 2011 | 03:25 PM
Jaster94's Avatar
i had a trailblazer cut out after a while of riding. turned out it was the coil. it was replaced and done fine.
Old Jul 31, 2011 | 09:27 PM
young#1's Avatar
the faces on the secondary was kinda messed up i tool my dremal tool and sand them down a little bit and then clean then clean them up nice and shiny and smooth and yes preloaded it. as far as the belt not sure will check tomar tho. the faces on the clutch pulley has like a mirror finsh to both of them not sure what they surpose to look like. ive clean the carb and set every thang to stock setting and wet from there. i am have to get that compression tool to see what i got. i wanted one any way got a few other bike so want hurt to have around.
far as the coil that has cross my mind a few time, is there a way to check it out or do i just have to switch it out and see what happens thanks for the help
Old Aug 1, 2011 | 04:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
could be your clutch faces are now bad as to why the belt is slipping. they have certain degree angles and if you had to grind it down then smooth it out that could be your issue.
Old Aug 2, 2011 | 10:03 PM
young#1's Avatar
it was like the bottons had made small marks on them but to me the bottons did not look to be warn that bad but idk im not an auto trans guy at all. so by me sanding them down a blt cause all of this. to just clear thangs up we are talking bout were the bottons touch inside the sec right
Old Aug 3, 2011 | 07:41 AM
Jaster94's Avatar
have you looked at the operation of the belt?
‪Polaris Sportsman CVT clutch‬‏ - YouTube
glad to know the dremel tool is not a lathe, just a spot grinder. i agree with stendori, the clutch faces are probably inadequate now....
Old Aug 25, 2011 | 10:13 PM
young#1's Avatar
so being i shaved to lil groves out the hexil it shot now and have to get a whole new setup. looked at the belt clips on youtube mines works as shown gose all the way to the end like there r doing. so i lose far as that gose. just sucks put the money into it and still havent gotten time to ride like i want to.
Old Aug 26, 2011 | 03:21 PM
Jaster94's Avatar
don't get discouraged. patience and perseverance will pay off in no time and you'll be enjoying your quad. but at least you'll know how to fix it.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
