AWD not engaging 2000 Xplore 400
Old Aug 13, 2011 | 02:29 PM
Palooza's Avatar
Default AWD not engaging 2000 Xplore 400
I have a 2000 Xplorer 400. The AWD quit working. The speedometer, low beam lights, and the neutral/reverse indicator lights have also quit on me. Based on this I'm guessing it is electrical.
Can anyone help out where to start?
I am looking for a wiring diagram for this machine but have had no luck. If anyone can tell me where to find a service or shop manual and/or wiring diagram I would really appreciate it.
Thanks!
Old Aug 13, 2011 | 10:39 PM
mrtwostroke's Avatar
is there are nice easy to follow circuit board on that like my 95. or is it just a mess of wires like my 2000 scrambler.
Well if you lost both sides. it's probably not a ripped out wires on both sides.
by-pass the switch on bars make that connection manually see what you get.
I guess this unit has an electric speedo. not sure where the sensor is
Is the high beam out too, starter work. battery charged
Old Aug 14, 2011 | 05:50 PM
Palooza's Avatar
I pulled out my multimeter and found that there is power to all of these (speedo, low beams, neutral/reverse indicator). Voltage regulator appears to be working, so I have no idea why all of these would blow at once. I've read somewhere that the speedometer controls the AWD, so I will replace this and see what happens. It's an analog speedometer but noteworthy is that that the same time as it all fried, the speedometer lens became cloudy and I can barely see the numbers through it.
Old Aug 14, 2011 | 06:29 PM
Kerbbirds's Avatar
Did you run it without abattery or with a bad battery? if so it blew all headligts, speedo ect, battery act as a buffer without it it puts out way too many volts and blowws bulbs ect
Old Aug 14, 2011 | 11:26 PM
Palooza's Avatar
I think you nailed it. I did indeed run it without a battery. I had no idea this would be a problem. An expensive lesson. How could this have affected the AWD?
Old Aug 14, 2011 | 11:32 PM
I was thinking abouy the dead battery thing later. ya been there done that. but don't have the electric speedo.
Old Aug 15, 2011 | 07:00 AM
TLC's Avatar
TLC
The 2000 Xplorer does have a digital speedo that runs off a "Hall Effect" wheel sensor that runs by wire not cable. Part #40. You have the same speedo I have. http://www.cyclepartswarehouse.com/f...2000&fveh=5510
The speedo must work to have AWD, the "wheel sensor" does not have to work though to have awd. There is a bypass wiring trick to get AWD back without buying a speedo. I,m not sure how its done but many people have done it. Do a search on this site.
My wheel sensor has not worked for years but the Speedo is OK and I have AWD. Only the speedo lights and hour meter works when the wheel sensor quits.
A bad Hall Effect wheel sensor and bad speedo are not the same thing in other words.
Did you run it with a dead battery or no battery installed at all?
Old Aug 15, 2011 | 07:15 AM
Palooza's Avatar
Thanks for your post TLC. Very informative.
Does anybody out there know the trick to get the AWD working by bypassing the speedo?
Old Aug 15, 2011 | 07:26 AM
TLC's Avatar
TLC
Here is one link on the speedo bypass. I HAVE A 1999 POLARIS EXPL 400 THAT WILL NOT GO - FixYa
Old Aug 15, 2011 | 09:36 PM
Do I assume correct that the speedo being incorporated into the awd, is only for the reverse speed limiter. I thought the old system was fine, not that I have it hooked up.
I know it has nothing to do with engaging the wheels, that is mechanical.
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
