Polaris Sportsman 500
Old Aug 30, 2011 | 08:20 AM
rudyrfd's Avatar
Default Polaris Sportsman 500
I'm starting to have braking problems on my quad. I removed the rear caliper off the rotor and found only 1 side of the caliper piston is moving. Is this the correct way for this caliper to work or are both sides suppose to move together. Greg
Old Aug 30, 2011 | 10:20 AM
What year model?? OPT
Old Aug 30, 2011 | 10:49 AM
rudyrfd's Avatar
Default Polaris
1996 Sportsman 500. Brakes felt loose and slowing down was a problem. Took everything apart to check the pads and they were fine. Fluid is fine. Just that rear caliper.
Old Aug 30, 2011 | 12:06 PM
Just has the one small piston on the 96 model and usually wears out the pad on the piston side,plus has the old mechanical emergency pedal that sometimes freezes up. You can turn in the adjuster screw on the lever and see if the pedal can free up the piston. If not, the piston and seal kits are still available. OPT
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
