First time ATV owner needs beginner help
Just as the title says. I bought a 'United Motors Moontrax 90' ATV for my two young sons. They had an electric BS quad but after two times through the yard the battery was shot and needed recharched. I figured the gas quad wouild be alot better as they could ride alot longer.
They guy who sold it to me showed me the 'govenor' screw on the thumb throttle. He backed it off so it goes about the speed they can handle. My questions is that as soon as they start going down hill it seems to kick in and the quad picks up speed and opens up. I even got on it and tried it and it went slow at first but after a few yards it started to open up to a speed I really dont want they to travel. This was on flat ground too. I am a total newb with ATV's but when I bought it I thought that this would limit the speed that the ATV can travel. I am guessing that it controls the throttle but if it is able to pick up speed it will. Is there a way to limit the ATV to a certain speed no matter uphill, downhill, or on flats? I look kinda crazy chasing my young ones through the yard yelling for them to stop. Any help is appreciated. Thanks.
Welcome to the forum eniced73!
The only way to truly slow down the atv would be to put a larger sprocket on the axle or a smaller sprocket on the engine.. the screw only limits the throttle...as youve found out.. the screw limits how far the throttle is opened.. not how fast it goes.
You can also teach your boy how the brakes work properly(no insult intended). I believe that's his and your best bet. If that doesn't work right off the bat then the sprocket change idea is the other best choice. It's not a hard job at all. Basic hand tools will do the job most times if you can find a proper way to keep the sprockets from spinning (don't use the gears). usually a wooden dowel in the sprocket will keep it from spinning while removing the nuts and bolts on the sprockets. Remove the front first if you are indeed removing the front one. Most times installing a smaller rear sprocket (less # of teeth) on the rear axle does the trick without having to touch the front sprocket.
