AWD in reverse
Old Oct 24, 2011 | 04:15 PM
bjones12's Avatar
Default AWD in reverse
For some reason or another I am having trouble getting my 700 to engage in reverse. Yes, I do push the override button. Any help would be much appreciated.
Old Oct 24, 2011 | 04:21 PM
Change you fluid first and see if its milky (if you've been in water) If doesn't help,then could have a cage or armature plate problem. OPT
Old Oct 24, 2011 | 04:24 PM
bjones12's Avatar
I know it isn't milky, so it must be the cage or plate. How much do those items cost?
Old Oct 24, 2011 | 05:05 PM
Make sure you have power to the front gear case also. As far as cage prices(if needed) other members will probably chime in and give you prices on John Deere,etc or other after market replacement cages they have used. You won't like oem prices that I would give you OPT
Old Oct 24, 2011 | 06:41 PM
bjones12's Avatar
It is an 02 Sportsman, and AWD will engage in High and Low even with switch turned off. Meaning no donuts or sliding around for me.... I want this fixed before it starts raining a lot there in Tennessee. Don't want to miss out on the fun haha
These roller cages can be replaced with a JD? Is there a thread that gives the specific model #'s??
Old Oct 24, 2011 | 08:37 PM
Kerbbirds's Avatar
Roller kit # MIA10666
Cage kit # MIA10667
Seal kit# MIA10654
Thrust bearing and washer # MIA10663
Armature PLate# MIA10656
everything you need to rebuild your front diff from local john deer dealer
Old Jan 15, 2012 | 05:43 PM
bjones12's Avatar
Cage kit # MIA10667
Seal kit# MIA10654
How many Armature plates?
Old Jan 15, 2012 | 07:19 PM
ONE armature plate OPT
Old Jan 16, 2012 | 07:35 AM
TLC's Avatar
TLC
There is a guy on this site who is parting out a 2005 700 Sportsman,it may have the same part you need.
Old Mar 13, 2012 | 11:36 AM
bjones12's Avatar
I am happy to report that my problem has been fixed!!!! It cost me $156.14, but it is well worth it. Thanks to all that gave input.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
