Lt-80 with broken rear end. PICS
Old Dec 17, 2011 | 01:40 PM
Reyn's Avatar
Default Lt-80 with broken rear end. PICS
My sons LT-80 is breaking at the bolts near the axle. I noticed it one day when he came to a stop it looked the rear end slid or moved opposite the frame.
When I found it,I can pull on the frame and the whole rear end axle moves. It is about to come out but it appears the aluminum housing around the bolt is slowly breaking away on both the top and bottom bolt.
Everything else engine wise is fine. How much would it cost to replace this and where could I find that rear end?
PICS
Old Dec 18, 2011 | 09:19 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Pm the year and I may have one or two! I have 4 Im parting out!!
Old Dec 18, 2011 | 09:31 PM
LT80's Avatar
LT80 Expert
All the same from 87-06
Old Dec 19, 2011 | 04:57 AM
Reyn's Avatar
It's an 05 but LT says they are the same. Let me know what you have and cost please. Also,I am in N.Bama too. I live 30 miles from Huntsville. Thanks,Jeff
Old Dec 19, 2011 | 08:19 AM
LT80's Avatar
LT80 Expert
FYI: I've had them break before. Altho your seems to broke pretty bad, I used to just tighten the bolts back up and run it.
Old Dec 19, 2011 | 08:50 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I wonder if drilling that case out just enough to slip a steel sleve in that bolt hole wouldn't help- looks like the alloy case can't take the constant jarring torque of the power train- seeing as both failures happened on the left side of the alloy housing.
Should be easy to find a steel sleeve at any hardware store like true-value with a matching high grade bolt- that should alleviate the squeezing pressure from the bolt on the case- and will give that case a bit more strength to resist the torque.
Old Dec 19, 2011 | 09:34 AM
DAMONSQUAD's Avatar
was that lower mount bolt loose before the damage happened? looks like its not tight at all, which may have caused the extra stress on the upper one that let go
Old Dec 19, 2011 | 11:41 AM
DSengineer's Avatar
Has been here a long time!
It looks like the bolts were possibly overtightened causing the casting to break.
greg74
Sep 10, 2019 03:03 PM
DFWSRT8
Aug 20, 2015 09:24 AM
DeFox500
Jul 26, 2015 06:32 PM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
