lt80 rear sprocket removal?
How do I get this sprocket off? Does the axle slide out if I loosen the 2 bolts on the other side? I have the 4 bolts out and the sprocket is over the axle now... The piece that holds the tire on with 3 bolts is welded on
I see now where it is supposed to come off by the piece that bolts up to the wheel but previous owner welded it there. Guess I could grind down the weld. Does anyone know if that axle on that side comes apart?
